美国Optomec新型混合制造设备金属3D打印与传统的机械加工合为一体!
国防航天能源
17:29
全新革命性的增材与减材复合加工设备,具备五轴智能化增减材复合制造过程,包含3D打印、修补、激光表面熔覆等工艺,均可以在一台设备内完成,满足客户对于一站式加工生产需求,缩短制造时间、降低材料成本,适用于航天、电子、汽车、生医及模具产业等复杂与精密零件的五轴加工,并搭载自动化工艺模块交换系统,完全性地提升整体生产性能。
Optomec在3D金属印刷领域一直活跃近20年,是世界知名的具有优良冶金性能的金属打印专家。我们有经过业界验证的LENS技术和广泛的工艺专业知识,在机床行业采用高品质的混合制造方法,混合金属结构制造是其关键的推动力。
Optomec将其金属AM技术封装在一个模块化LENS打印引擎中,可与其他金属加工平台(如数控铣床,车床,机器人,定制龙门架或台式系统)集成,形成混合制造能力。最近,使用LENS Print Engine技术升级了老式立式磨机,使得可以在同一部件上进行加法和减法操作,并进行一次设置。
混合制造机器简化金属制造应用,如网状快速成型,混合制造,原位修复,制造返修等。例如,混合制造机器通过使用最适合的每个过程来加速生产复杂的金属部件。在该示例中,使用减法加工来制造壳体基座,并且使用添加剂制造来在相同的机器上构建和完成薄壁结构。
混合制造降低采用AM技术的成本和培训障碍。 LENS打印引擎技术通过利用减色机床的自动化平台为金属3D打印提供了一个低成本的入口点。此外,混合动力制造机器将加法和减法过程控制集成到机械师已经熟悉的单个用户界面中,使系统更容易学习和操作。
Hybrid Manufacturing
Hybrid Metal Manufacturing represents greatpromise for industrial manufacturers.
Fadal Vertical Mill upgraded with LENS AMtechnology
Hybrid Manufacturing is the term used todescribe combining metal additive manufacturing (AM) technology withconventional, subtractive technology, enabling each process to work together onthe same machine and even on the same part. Hybrid Manufacturing reduces therisks and costs associated with adopting metal AM technology, providing a morepragmatic and evolutionary pathway for industrial manufacturers.
Optomec has been active in 3D metalprinting for almost 20 years and is a recognized world expert in printing metalwith excellent metallurgical properties. Our industry proven LENS technology andextensive process expertise in making high quality metal structures is a keyenabler for the machine tool industry to adopt the Hybrid Manufacturingapproach.
Optomec has packaged its metal AMtechnology into a modular LENS Print Engine which can be integrated with othermetal working platforms such as CNC mills, lathes, robots, custom gantries, ortable systems to form a Hybrid Manufacturing capability. Recently a vintagevertical mill was upgrades with LENS Print Engine technology enabling additive andsubtractive operations to be performed on the same part with one set-up.
Hybrid Manufacturing machines simplifymetal fabrication applications such as net shape rapid prototyping, HybridManufacturing, in-situ repair, manufacturing rework and more. For example,Hybrid Manufacturing machines speed production of complex metal parts by usingeach process where best suited. In this example, subtractive machining was usedto fabricate the housing bbse and additive manufacturing was used to build andfinish the thin wall structures all on the same machine.
file:///C:/Users/Jimmy/AppData/Local/Temp/msohtmlclip1/01/clip_image003.jpg
Complex Metal Housing Manufactured with HybridTechnology
Hybrid Manufacturing lowers the cost andtraining barriers to adopt AM technology. LENS Print Engine technology providesa low cost-entry point for 3D printing of metals by leveraging the subtractivemachine tool’s automation platform. Further, Hybrid Manufacturing machinesintegrate additive and subtractive process controls into a single userinterface already familiar to the machinist making the system easier to learnand operate.
Advantagesof Hybrid Manufacturing Machines
Lowers AM acquisition cost
Reduces operator learning time
Enables net shape 3D printed metal parts
Accommodates unique part sizes
Speeds production of complex metal parts
Enables increased machine tool utilizationfor repair, coating, re-manufacturing
如对此工艺技术需进一步查询,请联络Optomec授权中国经销商:
WKK王氏港建科技设备(深圳)有限公司
也可电话联系或加微信13923895350杨晓东,谢谢!
上一篇:曼透平实现首例将3D打印涡轮叶片用在燃机批产中
下一篇:波音前首席技术官John J. Tracy 加入3D Systems
 楼主| JimmyYang
2017-5-23 08:58:58 | 显示全部楼层
可电话联系或加微信福建13923895350杨晓东,谢谢!
 楼主| JimmyYang
2017-10-18 16:54:29 | 显示全部楼层
Optomec公司今天宣布推出一个新的金属3D打印机产品Lens 450。Lens 450 的核心技术与Lens系列的其它产品类似,都是用来修复、电镀和快速生产多种高性能金属部件。LENS沉积系统使用高功率激光的能量,在瞬间直接将金属粉末变成结构层。
LENS工艺过程发生在一个充满氩气的密室中,这里氧气含量低于10万分之一,以确保在金属沉积的时候不产生杂质。Optomec的专有粉末供给系统能够非常精确地向沉积系统添加所需要的金属粉末。当对象部件打印完成后,可以取出进行热处理,热等静压压制,机械加工,或以任何其他方式的处理。最后得到的全功能3维组件具有等同或优于使用锻造方式制造的部件的机械性能。
Lens 450 3D打印机可以处理各种各样的材料,包括不锈钢,钴铬合金,钛合金和高温合金,非常适合于小型金属部件的快速原型设计和维修。这个高性能的制造系统提供了一个使用1级激光速型的100立方毫米(64立方英寸)工作空间。其他功能还包括一个400W高亮度固态光纤激光器,送粉器,运动控制系统,以及专有的过程控制软件。
主要特点:
l  吹粉末沉积 - 可见的过程
l  快速设置 - 一种新材料可在10分钟内完成
l  快速凝固率(> 1000℃) - 新型微结构
l  气体完全控制 - 最高质量的全面保护
l  创建混合物 – 快速生成合金
产品规格:
l  工艺工作空间:100×100×100毫米
l  运动控制:3轴标准:XY轴线性表运动,Z轴龙门运动
l  定位精度:±.25毫米
l  线性分辨率:±0.025毫米
l  运动速度:60毫米/秒
l  沉积速率:最高80克/小时
l  软件:工作站控制; STL Editing; PartPrep slicing
l  外壳尺寸:1×1×1.5米,独立单元
Lens 450 3D打印机的首个用户将是美国匹兹堡大学的机械工程与材料科学系,在那里将被用于其新的先进制造教育计划。C. Isaac Garcia教授评论说,“Lens 450系统是一个很好的工具,可以进行基础研究和应用研究,培养学生学习金属增材制造行业成熟的技术。”
