该假肢模型名称为Hope#1 prosthesis ARM based on flexy hand(该模型仅用于公益,不可用于商业用途)
是jorge22在2018年9月25日上传至Thingiverse网站的目前项目还在更新中。原文地址为(有可能被墙):https://www.thingiverse.com/thing:3120391
数据文件下载链接:https://pan.baidu.com/s/1XmB9OiP4OjbnwbycTe41FA 提取码:l1oq
以下为谷歌机翻,不喜勿喷~原文后附
它是一种用于经桡动脉截肢者的假体,可用于4岁至成人的儿童,具有可热成型的美学覆盖物,并且在这种情况下特别适合在手腕上安装纺织针,假体具有手腕标记为更好地定位手,手是一个灵活的han2修改与访问门保持膝盖骨,并在通过手指的线程时具有更大的舒适度,手掌flexy hand2缩放到其实际大小的75%,插座分为两个部分,以优化印刷时间,旋转具有“平坦”的面,以水平打印,并获得更大的强度,手指使用尼龙tanza张力,通过囚犯螺丝连接到三头肌片的钢丝线这可以调节紧张。
这个设计是团队成员“YoQuieroMiProtesis3D”(https://www.facebook.com/groups/yoquieromiprotesis3d/)协同工作的结果,我们是一群志愿者,他们寻求帮助有需要的人,这个想法是为了提供这个第一个型号,以便它可以使用,欢迎所有的改进。
https://www.facebook.com/search/top/?q=yoquieromiprotesis3d%2Fmakers
打印设置
打印机品牌:RepRap
打印机:
RepRap Ord Bot Hadron
筏:没有
支持:是
解析度:0.25
腾空:30%o mas
细丝:R3D PLA任何人
原文:
It is a prosthesis for transradial amputees, can be used in children from 4 years old up to adults, has a thermoformable aesthetic cover and for this case in particular an adaptation was made in the wrist to mount a textile needle, the prosthesis has a wrist labeled to better position the hand, the hand is a flexy han2 modified with an access door to hold the kneecap and have greater comfort when passing the threads of the fingers,the palm flexy hand2 is scaled to 75% of its actual size, the socket is divided into two parts to optimize printing times, the rotula has a "flat" face to print it horizontally and achieve greater strength, the fingers use nylon tanza tensors that derive in a steel thread attached to the piece of the tricep by a prisoner screw that allows to regulate the tension.
this design is the result of the collaborative work of the members of the group "YoQuieroMiProtesis3D" ( https://www.facebook.com/groups/yoquieromiprotesis3d/ ) we are a group of volunteers who seek to help people in need, the idea is to make available this first model so it can be used and all improvements are welcome.
Se trata de una prótesis para amputados transradiales,puede ser utilizada en niños de 4 años en adelanta hasta adultos,posee un cover estético termoformable y para este caso en especial se hizo una adaptación en la muñeca para poder montar una aguja de tejer, la prótesis posee una muñeca rotulada para poder posicionar mejor la mano, la mano es una flexy han2 modificada con una puerta de acceso para poder sujetar la rotula y tener mayor comodidad a la hora de pasar los hilos tensores de los dedos,la palma flexy hand2 se encuentra escalada a un 75% de su tamaño real,el socket esta dividido en dos partes para optimizar los tiempos de impresión, la rotula posee una cara "plana" para poder imprimirla en forma horizontal y lograr mayor resistencia,los dedos utilizan tensores de tanza de nylon que derivan en un hilo de acero sujeto a la pieza del tricep mediante un tornillo prisionero que permite regular la tensión.
este diseño es el resultado del trabajo en colaboración de los miembros del grupo "YoQuieroMiProtesis3D" ( https://www.facebook.com/groups/yoquieromiprotesis3d/ ) somos un grupo de voluntarios que buscamos poder ayudar a las personas que lo necesiten, la idea es poner a dispocision este primer modelo para que pueda ser utilizado y todas las mejoras son bienvenidas
Print Settings
Printer Brand:
RepRap
Printer:
Rafts:
No
Supports:
Yes
Resolution:
0.25
Infill:
30% o mas
Filament: R3D PLA anyone
Notes:
上一篇:hANDi hand orthose假肢模型分享下一篇:Prosthetic leg from GrabCAD by Dexter假肢模型分享
