G code 含义
3D打印软件设计算法
2013
01/31
00:18
  1. G0: Rapid Positioning
  2. G1: Coordinated Motion
  3. G2: Clockwise Arc
  4. G3: Counter Clockwise Arc
  5. G4: Dwell
  6. G10: Create Coordinate System Offset from the Absolute one
  7. G20: Use Inches as Units
  8. G21: Use Milimeters as Units
  9. G28: Home given axes to maximum
  10. G53: Set absolute coordinate system
  11. G54: Use coordinate system from G10 P0
  12. G55: Use coordinate system from G10 P1
  13. G56: Use coordinate system from G10 P2
  14. G57: Use coordinate system from G10 P3
  15. G58: Use coordinate system from G10 P4
  16. G59: Use coordinate system from G10 P5
  17. G70: Use Inches as Units
  18. G71: Use Milimeters as Units
  19. G90: Absolute Positioning
  20. G91: Relative Positioning
  21. G92: Define current position on axes
  22. G97: Spindle speed rate
  23. G130: Set given axes potentiometer Value
  24. G161: Home given axes to minimum
  25. G162: Home given axes to maximum
  26. M0: Unconditional Halt, not supported on SD?
  27. M1: Optional Halt, not supported on SD?
  28. M2: End program
  29. M3: Spindle On - Clockwise
  30. M4: Spindle On - Counter Clockwise
  31. M5: Spindle Off
  32. M6: Wait for toolhead to come up to reach (or exceed) temperature
  33. M7: Coolant A on (flood coolant)
  34. M8: Coolant B on (mist coolant)
  35. M9: All Coolant Off
  36. M10: Close Clamp
  37. M11: Open Clamp
  38. M13: Spindle CW and Coolant A On
  39. M14: Spindle CCW and Coolant A On
  40. M17: Enable Motor(s)
  41. M18: Disable Motor(s)
  42. M21: Open Collet
  43. M22: Close Collet
  44. M30: Program Rewind
  45. M40: Change Gear Ratio to 0
  46. M41: Change Gear Ratio to 1
  47. M42: Change Gear Ratio to 2
  48. M43: Change Gear Ratio to 3
  49. M44: Change Gear Ratio to 4
  50. M45: Change Gear Ratio to 5
  51. M46: Change Gear Ratio to 6
  52. M50: Read Spindle Speed
  53. M70: Display Message On Machine
  54. M71: Display Message, Wait For User Button Press
  55. M72: Play a Tone or Song
  56. M73: Manual Set Build %
  57. M101: Turn Extruder On, Forward
  58. M102: Turn Extruder On, Reverse
  59. M103: Turn Extruder Off
  60. M104: Set Temperature
  61. M105: Get Temperature
  62. M106: Turn Automated Build Platform (or the Fan, on older models) On
  63. M107: Turn Automated Build Platform (or the Fan, on older models) Off
  64. M108: Set Extruder's Max Speed (R = RPM, P = PWM)
  65. M109: Set Build Platform Temperature
  66. M110: Set Build Chamber Temperature
  67. M126: Valve Open
  68. M127: Valve Close
  69. M128: Get Position
  70. M131: Store Current Position to EEPROM
  71. M132: Load Current Position from EEPROM
  72. M140: Set Build Platform Temperature
  73. M141: Set Chamber Temperature (Ignored)
  74. M142: Set Chamber Holding Pressure (Ignored)
  75. M200: Reset driver
  76. M300: Set Servo 1 Position
  77. M301: Set Servo 2 Position
  78. M310: Start data capture
  79. M311: Stop data capture
  80. M312: Log a note to the data capture store
复制代码
上一篇:Makerbot的Firmware的源代码下载地址
下一篇:STL文件的规范
