Gauntlet for (Cyborg Beast derivative)假肢模型分享
展翼计划
09:53
模型
该假肢模型名称为Gauntlet for (Cyborg Beast derivative)(该模型仅用于公益,不可用于商业用途)
是fflood在2014年5月3日上传至Thingiverse网站的目前项目还在更新中。原文地址为(有可能被墙):https://www.thingiverse.com/thing:262723
数据文件下载链接:https://pan.baidu.com/s/1rt9qMgU9yT7eVvrsqbzn7A   提取码:bn8u
以下为谷歌机翻,不喜勿喷~原文后附
摘要
为了回应Jorge的Cyborg Beast Gauntlet(http://www.thingiverse.com/thing:261462),我做了这个挑战,因为内部形状的角形对Shea来说不是很舒服。我也想知道是否有两套皮带和更长的长度将帮助Shea不会像她用手一样快速疲劳。这个手套有Ivan和David的5槽张紧器(http://www.thingiverse.com/thing:232291)融合在它的顶部。手套向上伸出一点,并有两个魔术贴带的空间。我使用了四个短的维可牢尼龙搭扣,柔软的一面“in”。一旦它们穿过内置的槽,我就可以缝上带子,但是现在我只是在它们上面打孔,然后用缩短的芝加哥螺丝(用珠宝锯缩短)作为“铆钉”来固定环。我需要稍微收紧一下循环,因为它们在循环中有很多松弛。我用5毫米厚的泡沫衬在手套的内侧,但是在下一个上面会切换到假肢和夹板友好的泡沫,因为它应该是防水的。
有关魔术贴封口的更多信息,请参见http://frankieflood.blogspot.com ... velcro-closure.html
有关可以通过尺寸,打印和/或装配机械手帮助有需要的人的位置的更多信息,请加入e-NABLE Google+社区,名为e-NABLE:
https://plus.google.com/communities/102497715636887179986
有关更多信息和故事:
http://enablingthefuture.org
https://www.facebook.com/enableorganization
更多图片:
DSC_8517_preview_featured.jpg DSC_8516_preview_featured.jpg DSC_8515_preview_featured.jpg DSC_8514_preview_featured.jpg DSC_8513_preview_featured.jpg DSC_8512_preview_featured.jpg DSC_8511_preview_featured.jpg DSC_8510_preview_featured.jpg
原文:
Summary
I made this gauntlet in response to Jorge's Cyborg Beast Gauntlet (http://www.thingiverse.com/thing:261462) as the angular inside shape was not super comfortable for Shea. I'm also wondering if having two sets of straps and longer length will help Shea to not get fatigued as quickly as she uses her hand. This gauntlet has Ivan and David's 5 slot tensioner (http://www.thingiverse.com/thing:232291) fused onto the top of it. The gauntlet goes a bit further up the arm and has room for two velcro straps. I used four short pieces of velcro with the soft side "in". I might sew the straps once they are looped through the built in slots, but for now I just leather punched holes into them and then used shortened Chicago screws (shortened with a jewelers saw) as "rivets" to hold the loops tight. I will need to tighten up the loops a bit as right now they have a lot of slack in the loop. I lined the inside of the gauntlet with 5mm thick foam, but will switch to prosthetic and splint friendly foam on the next one, as it should be waterproof.
See http://frankieflood.blogspot.com ... velcro-closure.html for more information on the velcro closure.
For more information on where to connect with people who can help someone in need with sizing, printing and/or assembly a mechanical hand please join the e-NABLE Google+ Community entitled, e-NABLE:
For more information and stories:
上一篇:Snap-Together Robohand假肢模型分享
下一篇:Drum Stick Prosthetic假肢模型分享
