该假肢模型名称为Drum Stick Prosthetic(该模型仅用于公益,不可用于商业用途)
是KaelumHasler在2017年6月25日上传至Thingiverse网站的目前项目还在更新中。原文地址为(有可能被墙):https://www.thingiverse.com/thing:2404149
数据文件下载链接:https://pan.baidu.com/s/1QC85gK1TOyFdgcm_zZrcsA 提取码:7a17
以下为谷歌机翻,不喜勿喷~原文后附
摘要
你好!几个星期前,一位当地的父母来找我,问我是否可以为她的儿子做一个鼓棒假肢,他的儿子手上没有手指,几乎没有拇指。我说我很乐意提供帮助,所以在这里!包含Autodesk Inventor文件,以便您可以根据需要修改文件。
打印设置
打印机:
习惯
筏子:不重要
支持:无
分辨率:.1
填充:40%
笔记:
分别打印每个部件,以确保合适。建议使用ABS,nGen或XT打印。如果需要进行任何修改,则包含Inventor文件。快乐印刷!
印后
部件
确保打磨/移除所有锋利的边缘,钻出任何孔,然后将蛤壳孔打到M3。在粘贴魔术贴之前清洁表面并泡沫好运!
需要的材料
你会需要:
自粘魔术贴
6毫米医用泡沫
1/4 - 20螺纹杆(至少4个长)
2 X 1/4 - 20个坚果
3个M5螺母和25毫米长M5螺栓
1个鼓棒
10 x m3 x 20mm螺栓(不锈钢)
打印:
1 x袖口
2 x m5拇指旋钮
1 x 1/4 - 20旋钮
3 x春天
1个手壳
1 x Palm Shell
1 x关节
1个DrumStick支架
原文:
Summary
Hello! A few weeks ago, a local parent came to me and asked if I could make a drumstick prosthetic for her son, whom had a hand with no fingers and almost no thumb. I said I would be happy to help, and so here it is! The Autodesk Inventor files are included so that you may modify the files to your needs.
Print Settings
Printer:
Custom
Rafts:Doesn't Matter
Supports:No
Resolution:.1
Infill:40%
Notes:
Print each piece separately, to make sure the fit is correct. It is recommended to print out of either ABS, nGen, or XT. The Inventor Files are included if any modifications need to be made. Happy Printing!
Post-Printing
Assembly
Make sure to sand/remove all sharp edges, bore out any holes, and tap the clam shell holes to M3. clean the surfaces before adhering Velcro and foam good luck!
Materials Needed
You will need:
Self Adhering Velcro
6mm medical foam
1/4 - 20 Threaded rod (At least 4 in long)
2 X 1/4 - 20 nuts
3 X M5 nuts and 25mm long M5 bolts
1 x drum stick
10 x m3 x 20mm bolts (Stainless Steel)
Print:
1 x cuff
2 x m5 thumb knobs
1 x 1/4 - 20 knob
3 x Spring
1 x Hand Shell
1 x Palm Shell
1 x Joint
1 x DrumStick holder
上一篇:Gauntlet for (Cyborg Beast derivative)假肢模型分享下一篇:A hands on enterprise
