多材料多喷头桌面3D打印机开发商Hyrel 3D公司新近推出了新款3D打印机:HYREL System 30。
System 30采用全金属设计,全封闭式打印仓,和独立的封闭式线材仓,隔离了在打印过程中可能带来的环境污染,提高了机器的安全性能。机器下方配备有紧急停止(EMO)按钮和发光控制屏;线材仓前方有回转式LCD触摸屏和内置PC;打印仓内配备有树状工具支架,可装载8个打印喷头,是目前所有桌面3D打印机中可装载打印喷头最多的一款打印机,而且打印喷头还可以根据用户的需求任意替换,甚至还能够兼容体积更大的挤出器。
多材料多喷头3D打印机Hyrel再推新产品HYREL System 30
而在耗材方面,Hyrel的多材料打印依然夺人耳目:粘土、橡皮泥、sugru、硅胶RTV,陶瓷,ABS,PLA,尼龙等等均在其可打印范围。
机器规格:
整机体积:87×42×79厘米
构建体积:225×200×200毫米
最高分辨率:20微米
整机重量:23公斤
价格:4000~7000美元
Build Volume, Posi onal Accuracy & Posi onal
Axis Travel Pos. Accuracy Pos. Resolu on
X Axis 225+ mm +/- 50 microns 5 microns
Y Axis 200+ mm +/- 50 microns 5 microns
Z Axis 200 mm +/- 20 microns < 1 micron
Chassis & Enclosure:
Powder-coated Steel & Anodized Aluminum
Acrylic Windows
Mo on Control:
Precision Ball Screw in Z-axis
IKO Linear Bearing System in X, Y, and Z Axes, rated to
20,000km before first manufacturer suggested lubrica on
Posi onal Resolu on
Electronics:
State of the art, 150+ MHz 32-bit ARM processor
Modular, micro-stepping motor-drivers
Integrated, Dual CAN-bus architecture
“Smooth Move” mo on control technology firmware
Integrated Web-Cam for build-area monitoring
Out-of-the-box, doors open & LCD fully extended
Weight: 50 lbs / 23 kgs
Length: 50 in / 127 cm
Width: 38 in / 97 cm
Height: 31 in / 79 cm
Out-of-the-box, doors closed & LCD fully retracted
Length: 34 in / 87 cm
Width: 16.25 in / 42 cm
ITX Power Supply Specs:
Power: 650 W
Voltage: 115 / 230 V
Current: 16 / 8 A
Frequency: 60 / 50 Hz
Physical On/Off Switch: Yes
IEC-60320 C14 connector
IEC-60320 C13-to-NEMA 15 Power Cable
US Standard—must supply your own if Interna onal
